Urban
Urban
Мнениеот ne4ovek » Пет Май 06, 2005 9:40 am
Какво е Urban:?:
ne4ovek
Регистриран на: Нед Юли 11, 2004 11:56 am
Местоположение: Zimbabwe
Мнениеот gladstone » Пет Май 06, 2005 3:16 pm
URBAN
['#601;:b#601;n]
градски
:dunno:
p.s. форума не поддържа транскрипционните знаци
gladstone
Регистриран на: Сря Юли 07, 2004 11:08 pm
Мнениеот atanas90 » Пет Май 06, 2005 6:50 pm
ами URBAN като стил на каране мисля че е просто градско каране или нещо като TRIAL в градска обстановка.
atanas90
Регистриран на: Вто Ное 30, 2004 2:42 pm
Мнениеот ne4ovek » Пет Май 06, 2005 7:00 pm
[quote="atanas90"]
И аз така мисля,ако греша-поправете ме,защото е важно:beer:
ne4ovek
Мнениеот hlebarka » Пет Май 06, 2005 7:13 pm
Цитат от [url]http://free-du.t-com.hr/trials/[/url]
[b]'Urban trials'[/b] is a mixture of trials techniques and urban environment. The result is a kind of riding easier and usually more fun than natural trials, because of widely available riding spots, good friction, right angles, firm terrain (concrete/asphalt) etc. The difference between urban trials and urban assault is in techniques used: urban trials retain basic trials idea, which is to get over obstacles without dabbing, using same old trials techniques, sometimes a bit modified; while urban assault is all about high speed fun, usually leading slightly downhill - at least in riders mind.
Most urban trials riders mix trials elements with street tricks, so any good urban rider will know how to manual, stoppie or fakie - there is always that element of pleasing the crowd (which is abundant in cities) that original trials miss, as rarely anyone will be in the woods staring at the rider doing crazy stuff.
Urban trials require stronger bikes because of shocks delivered by unforgiving asphalt and concrete, big drops on hard surfaces. Some riders opt for short-travel suspension forks, while others ride rigid forks and make their whole bodies act like suspension. Smooth bashguards are most often used to slide in on smooth obstacle surfaces, as opposed to toothed bashguards used in natural trials to bite into surfaces like wood or rock.
Some typical frames are: Planet-X Zebdi, Echo Urban, Koxx Urban, Onza T-Rex, Thylacine X-Trials, etc.
[b]'Street'[/b] is a discipline that originated in BMX world decades ago (and both worlds still share a a lot of same tricks), and it's based on 'eye-candy techniques', or tricks, designed to entertain the rider or the crowd, without any real use. It involves moves (tricks) like manuals, nosepicks, fakies, g-turns, rockwalks, (twisted) stoppies, catwalks, x-ups, barspins etc. Street riding on mountain bike is getting more often called jibbing, since it evolved a long way from BMX in 1980s.
Good example of an MTB frame that could be used for street riding is Goatbike Goatbike, Ashton ET24 (Edd Tongue Signature), Curtis T1 Street and KoxxST frames, Norco Moment, Author A-gang... Urban trials and street frames have very similar geometries and you can use both types of frames for both kinds of riding, but if you really want to know the difference, usually street frame will have shorter wheelbase, lesser head angle and they're usually built to accept suspension forks.
[b]'Urban assault'[/b] is, as its name suggests, aggressive kind of riding invented to damage urban stuff all over town, usually ridden on a bike with plush-travel suspension fork and a steel frame (or fat aluminum frame), like for example Planet-X Pitbull. When you see someone doing a high-speed drop down the stairs or launching off a wall, you can sleep tight knowing your eye has caught a piece of urban assault. Lately, a lot of riders opt for full suspension frames, knowing concrete is unforgiving. However, most of dirt jump and dual slalom frames will do for this kind of riding, since it requires frames that are designed for high speed stability and suspension forks.
hlebarka
Мнениеот chiMol » Пет Май 06, 2005 7:21 pm
Бах маааа му аз съм карал urban и да не знам ....
http://www.tiarakm.hit.bg
https://easycryptobot.com
chiMol
Мнениеот ne4ovek » Пет Май 06, 2005 9:08 pm
@hlebarka Благодаря ти,ама аз искам с два реда някои да ми обясни какво е,за да разбера:I
П.П.Не разбирам много от английски:banghead:
ne4ovek
Мнениеот Admin » Нед Май 08, 2005 10:50 pm
Е тотия неща трудно се обясняват с два реда ;) Намери някой да ти преведе цитирания от hlebarka текст, защото обяснението там е много добро :thumb:
Назад към Архив
